Next Saturday, I will be doing my first valve clearance adjustment on my 2022 ATAS. I will be using the video posted below and my service manual. This will be my first valve clearance adjustment on any motorcycle.
If you have any tips or pointers, please share. I’m not looking for you to explain the entire process, but if there is a trick or tip that you found helpful, I would appreciate knowing.
While I have my gas tank off, I am also going to adjust my crankcase breather hose as oil has been leaking all over my bike for the last 10k miles (I suspect it wasn’t put back correctly when a new wiring harness was installed by my dealer).
I will update this thread as I complete the maintenance.
Thanks,
Dillon
Thanks,
Dillon
