1 - 14 of 14 Posts
Ok - the red plug is for the HISS which no-one in the America's gets. I wonder can we add HISS?
What are the two unused white plugs under the rider seat?
I'm wanting to store tools, tire levers, tubes, and my air pump in the bike instead of externally carrying a bag with them. The pump will fit under the pillion seat, and a tube or two. My tool pack will fit under the rider seat - but if I want to store my tire levers under there then I'll need to reshape some of the plastic (and maybe bend the tire irons to match the curve of the wheelwell). I've changed tubes on the side of the trail - and I really want all 3 tire irons (damned mesquite!).
The toolbox can hold a patch kit, and the side panel can hold the kit and a tube - but not two tubes (and I don't want to split the stuff up). Does anyone have a better use for them? Under the riders seat and forward into the tank there is some dead space under the plastic ledge they put in to give it a uniform bottom. If I could find a black plastic box close to that shape - then I'm good at reshaping plastic. I could fit my tool bag with tire irons in that combined space. Everything under that ledge gets dirty - so it would have to seal up well to keep my electrics clean. So far I have a pigtail SAE on the battery that goes on to power a soundblaster, or gets disconnected to power the tire pump. I'm probably going to add a PC8 and run the pump, a voltmeter, a set of aux lights and maybe a heated vest - but carrying the tools I sometimes need is paramount before a PC8 and other accessories...
you can read the DTC from this red plug , with the honda tool or with a sumitomo/OBDcable and a ODB 2 Can reader
those are not empty , you have a diode (near the DLC) and a resistor connected
the "free" slot on left side is intended for a two pins red connector for HISS diag.
The OP labeled "Rear AUX Power"
You get both ON and switched. This connection is for vehicle alarm; so ideal for powering a relay but I would not use it for much else.
Here’s some of the info you can pull off the OBD2 plug, which by the way, also blinks out the code (using the abs light) just by having the scanner plugged in.
Reactions: jamnut
2018 AT DCT
I really wish I had more knowledge when it comes to electricity, circuits, and such, but I am curious as to why you would only use this connector to power a relay, and nothing else. So this plug would not be okay for just powering a 12-volt source, like low amperage lighting or something of that nature? Is this because it has power even after the ignition is off? Thanks.
I think it depends what the fuses protecting this plug are rated at and what other circuits share these fuses. Running additional items directly from the battery via a fused link with a relay connected to this plug minimizes the impact a fault may have on the bike's electrical system.
The 2019 ATAS has a 12V power point on the dash which is rated at 2A. The fuse for this circuit is 10A. First impression would be this is a good point to plug in a compressor when needed. Further investigation shows the fuse is also protecting the heated grips.
Agreed..
A 12v relay’s draw is rated in milliamps . So there is never any concern on overloading the circuit..
1 - 14 of 14 Posts
