1 - 6 of 6 Posts
Just in the process of doing the outex tubeless conversion and fitting Pirelli Rally STR’s, I need some weights to balance the wheels and I have 2 x oem spoke weights that are 15g each, one is not enough and 2 is too much, Honda also do a 20g one, but I’d have to order that one and it may well be not enough, will a couple of grams make a big difference to the balance?. Are there any alternative spoke type weights other than the Honda oem one available (in the UK) please.
Not really, the inside shape is designed to fit onto the spoke nipple and then crushed to stop them moving. I have found other types on fleabay that are made of brass, different lengths/weights and use a grub screw to hold them tight. These ones are made of brass, would that be a. problem with stainless spokes?
In the old days, lol, we had the same weights Honda use now, but they were lead, If we needed extra weight we tended to fit thick copper wire wrapped tightly around the spoke and kept in position with a little insulating tape, nothing fancy in them days,
1 - 6 of 6 Posts
