That video is comparing the old ezCAN to the new Denali CANsmart
Not a very good comparison seeing as how the ezCAN in the video was basically an old version.
Hex were on here asking for volunteers in the UK to develop the Sahara for the CRF1100, only once it was released then Denali released their different coloured version. Biggest difference between the two is the colour and text but also the Hex ezCAN doesn't come with wiring harness but rather just pigtails for making your own harness and if you want a harness you have to buy it as an extra, Denali comes with a harness.
So which is better? neither really as they are one in the same, support may be fractionally better for the ezCAN as you will be dealing direct with the manufacturers/inventorsbut time zones may also play a factor in how quick you get an answer.
For me buying without the harness was better as it meant I could make my own cables up to exact lengths for the routing I wanted to do and no excess plugs or joins etc. For people not comfortable with making their own cables up then I suppose the choice will be down to which is easier to buy in your location and which works out cheaper. For example the Denali comes with wiring for a set of lights and a sound bomb horn, if you don't want a horn then basically you are paying for the harness that you likely wont use although you may be able to repurpose it for a different accessory.
Here is the thread with
@StephanT talking about the upcoming Sahara.
hi all, Stephan here from HEX - I'm not intending on punting anything, but purely here to reach out to the community and find some enthusiastic owners that are wanting an ezCAN for their CRF1100 AND are (relatively) close to me... The pandemic is really screwing with many things, one of them...
www.africatwinforum.com
